Upgrade to Premium
Ski-Doo: REV Sleds 2004.5-200, all models in the REV chassis
Reply
  #1
Old 09-08-2009, 08:11 PM
jacmmaxwell jacmmaxwell is online now
Currently: wanting to ride
Basic Member
jacmmaxwell has a reputation beyond reputejacmmaxwell has a reputation beyond reputejacmmaxwell has a reputation beyond reputejacmmaxwell has a reputation beyond reputejacmmaxwell has a reputation beyond reputejacmmaxwell has a reputation beyond reputejacmmaxwell has a reputation beyond reputejacmmaxwell has a reputation beyond reputejacmmaxwell has a reputation beyond reputejacmmaxwell has a reputation beyond reputejacmmaxwell has a reputation beyond repute
Default Another mod out of the way for winter
Well, I'm waiting for DJ's clutch kit and my vents to get here for my RT1000 so I thought I would look into some drop brackets. I decided I would hack some out of some scraps from around the shop. They are not finished just yet but here is what they will look like, I need to drill a couple holes up at the top of the new piece and then finish drilling the bottom holes and get soem bolts. They are good for 1" and 2" drop, I plan to set them at two inches and redrill my front mount 1" down and maybe a 1/4 back as well but the rear set I will not be able to measure until the skid is on the ground. I wanted them to blend in, don't want the guys I ride with keeping up.
Rate this post: Yes | No
  #2
Old 09-09-2009, 07:45 AM
cubby's Avatar
cubby cubby is offline
Currently: Riding Atv's till the snow comes back
cubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond repute
Default
Looks good
__________________
2016 T3 154"
2007 XRS 800 151" engine built by SHR
2013 Polaris 850xp
2015 Polaris 1000xp
2016 Polaris 170 RZR
Hold it pinned till you feel bad
  #3
Old 09-09-2009, 07:50 AM
Basic Member
Default
I love working with aluminum, I used the table saw and my little cordless trim saw to make them. It only took about an hour to cut them out and drill them once I had a design figured out. I'm going to try to get them drilled and bolted in tonight so I can get it on the ground.
  #4
Old 09-10-2009, 05:22 PM
c-bolt c-bolt is offline
Currently: Working to play
Basic Member
c-bolt has a reputation beyond reputec-bolt has a reputation beyond reputec-bolt has a reputation beyond reputec-bolt has a reputation beyond reputec-bolt has a reputation beyond reputec-bolt has a reputation beyond reputec-bolt has a reputation beyond reputec-bolt has a reputation beyond reputec-bolt has a reputation beyond reputec-bolt has a reputation beyond reputec-bolt has a reputation beyond repute
Garage
Default
Should work pretty good. If you go with the bottom hole, you will most likely want to drop the front as well (like you said). That way you wont have WAY too much ski pressure.
  #5
Old 09-10-2009, 05:44 PM
mxracer328 mxracer328 is offline
Currently: making snow babies
mxracer328 has a reputation beyond reputemxracer328 has a reputation beyond reputemxracer328 has a reputation beyond reputemxracer328 has a reputation beyond reputemxracer328 has a reputation beyond reputemxracer328 has a reputation beyond reputemxracer328 has a reputation beyond reputemxracer328 has a reputation beyond reputemxracer328 has a reputation beyond reputemxracer328 has a reputation beyond reputemxracer328 has a reputation beyond repute
Default
how thick of aluminum did you use, i was thinking about making a set of these for mine too, doesnt seem like it would be to hard to do
  #6
Old 09-11-2009, 07:55 AM
Basic Member
Default
I used 3/8 but I think that is a little over kill. I think 1/4 would have worked fine, I just had the 3/8 laying around. I have not gotten any further on these but when I do get it finished I will get some more pics.
I got a box in the mail yesterday with a couple spools of shiny wire and a regulator? Hmm , maybe that new 250 cubic ft bottle of argon in the shop has a use after all ?? I have a couple other projects in the works but first I need to play with the welder some more before it touches my sled.
  #7
Old 09-11-2009, 11:33 AM
Default
i think a sled deck is perfect practice before you touch ur sled with it, just do the welds you cant see to start out with
  #8
Old 09-11-2009, 12:57 PM
Basic Member
Default
An aluminum sled deck is not in the budget this year, honestly I think I would build one out of steel anyway. I could buy a used aluminum deck for around the same cost as building one.
It will not take me long, I've been burning steel for the last 15 or so years. I played with it for a bit last night and found the wire speed to power setttings to be much differant, electrode travel speed is much faster then steel and that will take some getting used to. I also spoke with my father ( been a welder / millwright / machinest for over thirty years ) sugested I try to change my gun position from dragging to a slight push but I have not had a chance to try that, he works at Mayfeild/Mossyrock damn and they use tons of aluminum in there power house and most of the time he uses mig so I trust his advise... plus he's my dad what can a guy doo.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
no new posts
