I'm not a professional installer and I did this with simple tools found in a garage. Good quality material and simple to install for the price!
FROM #ARCTICFX website #makeityours
Our graphics are 16mil thick and made with AFX exclusive AIR-PASS© Technology, an industry first. Tiny channels have been cut into our highly aggressive, pressure sensitive adhesive to give you the best vinyl product for power sports in the industry. This means that absolutely NO liquid is required for installation. Our exclusive AIR-PASS© channels allow air to freely move under the graphic and pass through the channels as you squeegee down, resulting in a bubble free install. If you do happen to encounter a bubble, it is highly likely that you will still be able to push the air through these channels
for up to an hour after install. However, depending on the ambient temp, squeegee pressure applied, and/or other environmental factors, you may still need to use the old poke with a pin method. It is important to apply a low to medium heat to all the graphic surfaces, paying close attention to the edges, and run over them once more with a good pressure on your squeegee after you are satisfied with the install in order to close these air channels permanently at the time of installation. While the channels will eventually
close on their own due to the aggressive nature of the adhesive, in this way you can be certain you will not have any immediate issues. Please allow 24 hours after installation to achieve a full bond to your plastics.
