Hello, I haven`t ridden the sled yet but I have also cut and motched my skid plate back like in the pic above or below which ever you have you threard settings set, make a ton of sence to me, I also softened my front shocks and think about it an try it , if on hard ground you loosen you front shocks up and then try to tip the sled to the left for instance the suspension squishs and lays over alot more effortlessly, now if you are on soft or harder snow, this to me would be even more effortless since hard frozen dirt is not forgiving and the skis can`t sink down like they can in snow, so I`m hoping my powerturns and hillside carvs HAVE to me alot easier to execute, along with loosening the limiter strap should be a huge difference,
Last year I did a sigmificant cut out on my 6.9pilot skis and shortened the rear of them 2.5inchs along with swapping them from side to side and just that mod made alot of differece also after swapping removed the now Inside carbide, seen no need for it there and makes the ski lighter.
I know these adjustment were a big difference on my S Chassis and they have to be even better on the Rev, I also have a 15inch track but don`t really think 15to16inch makes that much difference on carving or sidehilling.
Wildcard,
this mod also mades a big difference to where your feet set whether your wrong foot forward or nuetral position etc. get your feet forward more and more stable footing, cut the side panel to the same shape as the footwell bracket.
also remove the footwell loop piece that wraps around the bracket , keeps your boots from getting caught in them if you fall off the side of the sled, they can catch you boots twisting your ankle and dragging you from the sled, Ttabs on dootalk explains this and he almost broke his ankle so he raised the loop bracket up to clear boots when slid in on there side , should be able to put boot in and then tip them sideways and not touch of hang up on the aluminum sheetmetal loop that used to be there in this pic if boots bind on them redrill holes higher and bend loop up or just cut them out like I did and it looks cleaner too.
Good Luck, Wildcard
