i have an 07 summit 800r 151" love the sled... low miles maybe 400. I have heard these engines are ticking time bombs... The clutching is right now from the factory pulls 8500rpm... The Y pipe bolts have come out of course... What do i need to do to make this sled run? I don't want to be stuck out in the backcountry with this sled!! Is there an update kit for the motor?? If so how much?ETC
The 151 came with the good track.. no need to swap it.. it works fine..
I have the same sled and it is a joy to ride..
I would NOT fix the primary clutch.. it will still have issues even after changing out parts.. Get a TRA III and throw the TRA 7 away.. Done TONS of comparisons between the 2 clutches.. there are more issues than mentioned with the TRA 7.. lose the head ache.. you will be much happier...
We also dedveloped an awesome TEAM tied set up for the 07 800R.. It was amazing the difference over the HPV27.. Very surprising.. but the HPV can be made to work well also.. But the primary can not. IMO..
Great sled.. Congratulations.. you will love it!!
Kelsey
