B
Specs (07 Rev 151 800r)
Now maybe my logic is a little backwards so hopefully somebody can please give me a hand a clear things up, I made a number of changes to my sled and I'm noticing "perceived" positive, and negative impacts.
This summer, I did the following (in this order)
As a result of a backshifting, and inability to sustain RPM under load or get peak RPM issue I changed my secondary to a team tied
The result was a snappy respond and quicker shifts, quicker and smoother shifting and quicker shifts between forward and reverse, but It didn't fix the peak RPM.
I then went ahead and did the following things all at once (I meant to space them out, test, and then try another..but as a result of a lack of snow and bordem I did them all at once)
1) Replaced my R.A.V.Es with 09 Raves (my 07's were cracked)
2) Replaced my head with a used trygstad billet head for my altitude
3) Replaced my top gear in the chain case with a 19t (and replaced fluid adjusted chain tension)
4) Rebuilt my Primary with specs provided by team to match the above (Yellow & Almond Team spring, and & 13.8s weights currently going to order smaller weights)
5) Replaced my belt (166)
6) Let out the limiter strap.
Now this weekend finally got my first pow ride, and here is what I noticed.
Clutch engages around 4100-4200 rpm
Sled Seems "less snappy"
Sled is capable of pulling 8800 RPMs in the flat (I had to 3/4 throttle it or I was afraid it was going to hit 9k)
Sled is capable of pulling around 8400-8500 on a small climb (and so far seems to hold, I was unable to hit the hill I was testing before when it would drop and bog due to a lack of snow on that part of the mtn atm, but will do afte the next storm)
Sled doesn't seem to lift the ski's much anymore (maybe a couple inches (and no I didn't get weight.. quite the opposite.. I'm down 60lbs)
MPH is drastically reduced.
Currently my clickers are on 4, I'm thinking of dropping them to 3), I haven't rejetted the carb but it seems to be running good in terms of not leaning out, would the new head cause it to run rich?! I would assume I would need to add more fuel. If I was running lean it would be Snappy as all heck no?
Secondly I assumed by putting in a 19t gear, and letting out my strap it would turn into a wheelie monsters which leads me to believe I am for some reason now down on power, or is my logic totally backward, and could it be the weights are to heavy in my primary?
Outside of that I'm really happy with the sled. I just want to make sure I dial everything in. So with that said, does everything as I described seem spot on, or did I miss something? Thank you for your time!
-Brahm
-Brahm
