As mountainhorse said, this thread was in no way meant to bash MTNTK. I think the kit is running awesome, and I wouldn't run any other kit. I just wanted to try to solve a small problem I saw.
I am getting the soft spring for the TS Kompact Dual Port today. I can measure the length of the stock CRV spring that I cut when I install the TS valve. Probably install it after riding tomorrow, assuming I can get it to actuate at a low enough vacuum.
I am going up to the mountains tomorrow (8000'-9000') to test if the stock CRV valve is still functioning properly up there. Theoretically the motor will produce less vacuum at altitude so we'll see how that effects the surging.
I will have more varied riding conditions to test on/off throttle boost response. Then I will determine if I see any negative performance aspect of the modification to the CRV spring.
It's holding 8 psi of boost @ 5000' right now. I have another short clip of it in slo-mo since the camera moves so much in real time it's hard to see the gauge.
<iframe width="560" height="315" src="https://www.youtube.com/embed/tMXY5mjKOKk?rel=0" frameborder="0" allowfullscreen></iframe>
https://www.youtube.com/watch?v=tMXY5mjKOKk
