Not yet, but working with Factory Connection to get higher rate spring made, then I'm sending them my forks.
Don't remember the spring size, but they think it should act about like .60 in an Open chamber.
With valveving, hopefully we'll get a working setup.
.60 with slow compression may be ok, what was the cost?
The Dirt Lab - DivisionMX Suspension in North Salt Lake City, 801-683-8334. Call Jesse and Darin. They are great with snowbike setups. My front forks are great in deep powder and handle rough trail awesome. They are in most cases much cheaper then $850 for springs and revalving.
Installed my forks tonight, with ORSS with a 10.3NM spring and had the valve fork redone. Totally good. Probably the stiffest forks I have had, very good valve job. I have a softer 9.6NM spring and will likely run that one as the 10.3 is VERY stiff. Will give full review after a ride this weekend. Either way, there is no need for stiffer springs than what is available now.
Yes. In stock format, ie. Just adding the ORSS and keeping the right side fork stock was way to soft on comp(for me), and slow and sloppy on rebound. I did try crank up the compression and pre-load. There was a very big difference between stock and revalve. Now it takes a lot more force to compress, more as it gets to the bottom, and rebound is very strong. Very big difference from stock form. Night and day. IMO.
Yes I did. It was brutal. The forks would almost bottom out just jumping on the bike in the shop. I didn't actual ride it like that, it was that bad just jumping on it, and I'm 165lbs, so I immeadiatly send the other fork away.
K tech sells the spring conversion and the inners for the valving side replacement cartridge as a full kit as well.
