Next Generation Silber Turbo Pro RMK Kits
Silber
549
93
We have been spending countless hours developing our new 2013- 2014 Pro rmk turbo kits. We are excited to annouce we will be using the new Bully Dog tuner with the kits, and kPa Ceramic Ballbearing Turbochargers.
We have developed turbo mapping into the stock ECU, this allows your sled to function 100% like a stock snowmobile with the extra power of the turbo kit. Silber turbos is the only manufacturer to have this system working on a turbocharged Pro rmk.
Silber Turobs has been working on this setup all season and have waiting to release to the public until now. Unlike others that just recently got the chance to view the Product, we have 100's of testing hours with this new setup. We have a production map done and ready for the turbo kits.
We are confident this turbo setup will set the bar in Pro rmk Turbo History.
Please take the time to watch our video that will explain more about the new turbo kits. We will be doing a limited number of turbo kits this season if you are thinking about turboing your Pro RMK contact one of our Dealers today.
Also stay tuned for more videos and pictures. Please feel free to contact us at Silber Turbos or anyone at Nextlevel Powersports with any questions or concerns you may have regarding this new turbo kit.
http://www.youtube.com/watch?v=keg556BePHE&feature=youtu.be
Boston Racing
1,628
Colorado Springs, CO
From Edavis's thread on the other post
· How does this compare to the Vipec and its abilities
This will do most things the Vipec is capable of at a fraction of the cost and is truly plug and play with no need to modify the wiring harness or add a fuel pressure regulator. The Vipec has an Anti-Lag feature and will control a boost solenoid. I am sure it can do allot more and make you a pancake but for 95 % of the users out there the Bullydog does everything you need, including timing control:face-icon-small-coo
· Will we be able to tune remotely
Yes, We can remotely tune the units but there will not be a need to unless we are troubleshooting.
· Does it auto compensate for altitude change
Yes, just as your stock sled would.
· Is it strictly plug-n-play?
Yes, No additional wires or fuel pressure regulators are required.
Silber
549
93
We had to rework the video, due to some speech errors. The correct video should be live hopefully tonight or tomorrow that you can hear the sleds run and we talk about the system throughout the video.
Thanks
Boston Racing
1,628
I have received several questions about the Detonation Sensor, It's fully active with the Silber Turbos configuration. We believe the DET sensor is a valuable safety feature.
Blown Motor
1,427
1,016
So the new setup will control boost, altitude comp, barometric comp, outside temp, and all those factors?? And if it runs bad, do we need to send the box back to you for a new flash?? This would be the only way it would work correct? Because if all of these things are constantly changing they would have to be tuned to correct?
Boston Racing
1,628
1 .Boost will be controlled by a manual boost controller. The ECU will not have to be re calibrated for differences in boost pressure.
2. Altitude Calibrations will be handled just like the stock sled. Automatically
3. If there is an issue you can capture a datalog and we make changes via the web.
This system will change the way people think of turbo sleds. This will act in every way like a stock sled except it can now account for boost.
Silber
549
93
The box currently does not control your Boost Level. The kits will come with a boost controller to control that factor.
It does correct for all of these and more:
EGT
Baro
Watertemp
Airtemp
Det
Over rev
There will be no tuning needed for the end user. We designed this to work with our production turbo kit, if a user modifys his sled beyond that point tuning may be needed. We can remote access it or send you maps to be loaded into your stock ecu. There will be no need to send your box back into us.
Thanks
Boston Racing
1,628
Will your "stock" mapping be reducing octane requirements now that you have control over timing?
Yes, The video Silber posted is 8 pounds on 91 octane. The seal level guys may still have to add a little of the good stuff but that will all be covered in the instructions when the kits re released this summer.
Iceman56
1,249
466
83
EGT
Baro
Watertemp
Airtemp
Det
Over rev
Thanks
IAT or charge temp??
