T
We are out in Cooke City riding. Sled has run good for 3 days straight now. Ran good most of the day today, towards the end of the day my buddy took the sled for a rip, ran fine, I fired it back up to head in: now the sled is only running on 1 cylinder. Couple strange things: when I 1st started it up after my buddy rode it there was a wierd metal rattling sound and wasn't running right.(there was a chunk of stick in the by the primary clutch, I thought this was the issue, but wasn't) I shut it down and started it up and the rattling went away eventually, but its only running on 1 cyl. We changed the plugs, no change. We towed the sled in.
what we have done:
-We have tested spark, it has good spark on both cylinders. The MAG side isn't running though. We pulled plug wires to test, the sled runs when we pull the mag side(terrible still obviously), when we pull the PTO side the sled won't start. that's how we came to the conclusion the mag side isn't running. The MAG side piston is also wet like its not running.
We did a compression test, both cylinders are at exactly 90psi,that seems low, but we are also sitting at 7600ft elevation too. But they are both the same.
-We looked at the pistons and rings through the spark plug hole and VES openings and they look normal.
-The sled barely runs, it doesn't clear out if I try revving it up. It won't rev over 5500rpms.
No check engine light.
Sorry for the long post.
Any ideas?
what we have done:
Any ideas?
