BELT TO SHEAVE CLEARANCE
Any one know how to get rid of the annoying squeal at idle on the 08 dragon 800
^^^^^^^^^^^^^^^^ as the others have posted, which can re fixed by OPENING UP the secondary with the adjuster bolt & jam nut. You want the belt to be slightly higher than the top of the secondary belt, in a perfect world.
OR
It's a generic belt, or possibly the wrong belt???? that's TOO short, too wide?? try another, even a used belt off your buddies IQ or EDGE sled, see if it's the same problem
OR
Check your SIDE clearance, (belt -to-sheave) with a flat feeler gauge, you want approx .015" to .020" in a perfect world.
You didn't happen to just change weights did you?
Some weights (like the MTX series) have a TALLER shoulder and "close up" the clutch, possibly causing the problem you're describing.
Hope this helps
