Sled and mods are listed below.
Half way through the day my m1000 started studdering when you pin it, not at first but after it hits full rpm for 3-5 sec. Pulls real hard at the start but a few sec after you start a pull it then start this act like its hitting a rev limiter, around 72-7700rpm (my clutching was a little off thus the wide range of rpm) Any one had this happen and any ideas what it is. I'm leaning toward the injectors cutting out but ????? First thing will be to disconnect fuel controllers and then all other switches, but it would be nice if I didn't have to waste a day figuring it out.
Also my thumb warmer and right hand warmers are dead, i think because the throttle block got twisted(last year) and the wires/sodder finally gave out. Thumb warmer has not worked for a while and never had the problem but I think it started around the same time the right hand warmer quit( can't be for sure because it was warm out), I will have to look into it when I get a chance but wouldn't think its the cause.
This is also right after a new crank.
I know there are many reasons it could do this but if anyone has had this exact thing happen it would be nice to know, thanks.
