The 2001 SCS. What a great sled!! I still have the old girl to this day. I love the red hood, red seat and graphics. I thought the SCS came stock with the 151.
Before removing your swaybar you should try to ride a sled with it removed. I have always preferred the feel of the sled with the swaybar.
Back in 01 I believe the stock secondary clutch was still the button clutch so upgrading to the Team roller is a nice adjustment. SLP Air box kit is a nice improvement along with the SLP florites in the dash. Let me know if you are interested in a Gen II SLP air box kit as i have one. In fact I think I have two. The SLP single pipe is the way to go. SLP does great port work. I have had both Simmons and SLP Powder Pros and they are both excellent for the Gen II chasis. The v-force reeds are nice and that little steering post bracket thing to better support the steering post is a nice little adjustment.....I thinks its made by Sno-tek.
You might find that adjusting the limiter strap, front/rear shock and torsion springs for proper weight transfer really helps hillclimbing.
I also went with a camo 151 challenger and hyperfax and love the setup. The last thing I've done is go wiht the Fabcraft moutain bars...they are super. Oh I forgot, at some point I dropped in a PSI 1085...real nice but now I am back to a PSI 890. The only adjustments I made specifically for the PSI motors were to add a suplemental rear cooler and a water temp gauge in the dash.
Here's a tip...when using the seat pouch put your things in a plastic bag to keep them dry or they will be soaking wet.
The Gen II is a great chasis and either stock or modified you cant go wrong. It's bullet proof. I'm not sure stuff like drop and roll and relocating the skid will do all that much for you. I think your $$ is better spent on HP.
[/IMG]
