In good condition. Zippers work on all compartments. Velcro holds great around the air bag. A few scuffs on the exterior. Has a separate compartment that houses mechanism and canister. Shovel pocket will hold a KLIM shovel. Side pockets hold shovel handle and probe are easily accessible from the outside. Trigger is set up on the right side and it has a full zipper on left side to route radios etc. Left and right leg, chest and waist belt straps. Two waist belt pockets. Also has an easy access fleece lined goggle pocket.
Has the updated trigger mechanism. Tested after the new trigger install and worked perfect.
Uses compressed air canisters. You can fill these at home with an air gun pump. Roughly $130 online. Test fire twice and the pump is paid for compared to the other systems. No canister included.
