Upgrade to Premium
Polaris: Pro-Ride 2010 and up, all models in the Pro-Ride chassis
Reply
  #1
Old 03-26-2019, 12:56 PM
Kachess1 Kachess1 is offline
Currently: Not set.
Basic Member
Kachess1 has a reputation beyond reputeKachess1 has a reputation beyond reputeKachess1 has a reputation beyond reputeKachess1 has a reputation beyond reputeKachess1 has a reputation beyond reputeKachess1 has a reputation beyond reputeKachess1 has a reputation beyond reputeKachess1 has a reputation beyond reputeKachess1 has a reputation beyond reputeKachess1 has a reputation beyond reputeKachess1 has a reputation beyond repute
Default Four-stroke Pro's
Built 2 more naturally aspirated four-stoke Pro's this year and have a winter's worth of riding on all three. Have $2500 to $3000 into each of them since we all already had RX1 motors to donate. Reasonably simple swap. No machining, simple wire feed welding. Fortunately cheap clean Pro's with blown motors are easy to come by. We have them on 2016, 2014, and 2011 chassis's and they run head-to head with their 2-stroke brothers. My 2016 RMK 457# before, 469# after swap. Motors have anywhere from 5k to 14k miles on them but all run strong/identical. Next step is anti-ratchets: have to run tracks crazy tight. Fuel injected; improve running on steep downhill carves. Try a 163in Track. Very fun!
Here's riding in McCall last week. https://youtu.be/9y4tFI1D03Y
File Type: jpg 20190321_142353-1-1_1553626938759_resized.jpg (399.8 KB, 278 views)
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following 6 Users Say Thank You to Kachess1 For This Useful Post:
Motorbreath_ (05-26-2019), Norway (03-30-2019), RX1MountainMan (05-06-2019), Snowman.PRO. (04-09-2019), TRS (03-26-2019), zx4ever (03-26-2019)
  #2
Old 03-26-2019, 05:21 PM
turbolover's Avatar
turbolover turbolover is offline
Currently: Working on the new/Old School Tow Rig.
turbolover has a reputation beyond reputeturbolover has a reputation beyond reputeturbolover has a reputation beyond reputeturbolover has a reputation beyond reputeturbolover has a reputation beyond reputeturbolover has a reputation beyond reputeturbolover has a reputation beyond reputeturbolover has a reputation beyond reputeturbolover has a reputation beyond reputeturbolover has a reputation beyond reputeturbolover has a reputation beyond repute
Garage
Default
So what motors are you putting in them? Pretty neat to see someone doing something different from the crowd.
About the only real drawback I can see on that is when you get stuck, you probably don't want to get that 4 stroke on its top.
I usually end up with my sled upside down to get it unstuck at least a couple of times every ride.
__________________
14 800 Pro RMK 163
09 600 RMK 156
  #3
Old 03-26-2019, 05:40 PM
Currently: Not set.
Basic Member
Default
We typically roll our sleds out of stucks at least a couple times per ride. The RX1/apex motor has a dry sump so most of the oil sits in a reservoir. The little oil in the crankcase can run out the breather tube into the airbox when upside down. Only good thing about our carb versions is they shut off when they go upside down so we don't toast motors. We can roll out 3 or 4 times and not go low on oil. I have installed a solenoid valve on the breather before but feared it might malfunction and I don't want to build crankcase pressure. Been rolling them out for 15 years. A little oil out the belly pan once in a while is not a big deal.
The Following User Says Thank You to Kachess1 For This Useful Post:
Norway (03-30-2019)
  #4
Old 03-30-2019, 02:24 PM
Norway's Avatar
Norway Norway is offline
Currently: gettin ready to ride!
Norway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond repute
Default
Way cool. Congrats on some fine builds. They do sound awesome and if the weight penalty is only around 10-12lbs, kudos for a good quality build.
Sent fra min S60 via Tapatalk
__________________
«puny god»
http://revver.com/video/310519/a-dozen-more-turns/
The Following User Says Thank You to Norway For This Useful Post:
  #5
Old 04-01-2019, 10:42 AM
jim jim is offline
Currently: Keyboard highmarking at its best.
jim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond repute
Default
Turbo any of them? How is the handling compared to a stock Pro? I found the Apex to be very heavy front handling.
  #6
Old 04-04-2019, 05:56 PM
Currently: Not set.
Basic Member
Default
We've ridden lightened RX-1's 159's (less 80 lbs from stock) for years and have been able to make them go most anywhere. The yami motor in the pro chassis is another 60lbs lighter and massively more maneuverable. We are still learning what they can do. They're super easy to lay over, can hang a crazy steep sidehill and downhill carve like nothing we've ridden. The video has some sidehilling. Unfortunately none of have experience with stock pros. Our chassis's had blown motors. I guess our next step will be to let an experienced pro rider run them side by side.
  #7
Old 04-04-2019, 06:59 PM
TRS's Avatar
TRS TRS is online now
Currently: 2019-2020 winter on the way
TRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond repute
Default
Quote:
I know an old boy that has that oil loss issue fixed. Send me a PM and I’ll give you his number.
  #8
Old 04-07-2019, 01:13 PM
Currently: Not set.
Basic Member
Default
Thanks for the tip. As far as Turbo's in any or them, not yet. There is plenty of room alongside the motor but I'm thinking the Apex fuel injected motor is a better candidate. We messed with MCX and Bender rear mounts on our RX1's but they added a lot of weight and we had to constantly fiddle with them. Another summer project will be seeing if we can get the Apex fuel injection rails to fit. Clearance between the motor and the steering link is pretty tight.
  #9
Old 04-07-2019, 03:03 PM
TRS's Avatar
Default
The gent I sent contact info on, can help you in the turbo dept also.
  #10
Old 05-24-2019, 11:05 PM
macsummit macsummit is offline
Currently: Not set.
Basic Member
macsummit has a reputation beyond reputemacsummit has a reputation beyond reputemacsummit has a reputation beyond reputemacsummit has a reputation beyond reputemacsummit has a reputation beyond reputemacsummit has a reputation beyond reputemacsummit has a reputation beyond reputemacsummit has a reputation beyond reputemacsummit has a reputation beyond reputemacsummit has a reputation beyond reputemacsummit has a reputation beyond repute
  #11
Old 05-25-2019, 05:06 AM
NHRoadking's Avatar
NHRoadking NHRoadking is online now
Currently: Wanting more snow
NHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond repute
Click Here to Register
  #12
Old 05-25-2019, 11:44 AM
sno*jet sno*jet is online now
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
  #13
Old 05-26-2019, 09:55 AM
MKULTRA MKULTRA is offline
Currently: braaapping
MKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond repute
  #14
Old 05-26-2019, 11:19 AM
NHRoadking's Avatar
  #15
Old 05-26-2019, 11:50 AM
Motorbreath_ Motorbreath_ is offline
Currently: You have reached thelimit of your Free BasicMember readingprivileges.
Basic Member
Motorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond repute
  #16
Old 05-26-2019, 02:37 PM
SNWMBL SNWMBL is online now
Currently: Not set.
SNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond repute
  #17
Old 05-29-2019, 04:43 AM
Killer Time Racing's Avatar
Killer Time Racing Killer Time Racing is offline
Currently: Need more current , to get current
Killer Time Racing has a reputation beyond reputeKiller Time Racing has a reputation beyond reputeKiller Time Racing has a reputation beyond reputeKiller Time Racing has a reputation beyond reputeKiller Time Racing has a reputation beyond reputeKiller Time Racing has a reputation beyond reputeKiller Time Racing has a reputation beyond reputeKiller Time Racing has a reputation beyond reputeKiller Time Racing has a reputation beyond reputeKiller Time Racing has a reputation beyond reputeKiller Time Racing has a reputation beyond repute
The Following User Says Thank You to Killer Time Racing For This Useful Post:
NDRMK (06-24-2019)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2 stroke or 4 stroke, both turbo hill climb comparison Thread Starter — Jordy 800 Forum — Ski-Doo: XP Sleds Replies — 4 Last Post — 01-15-2014 03:29 PM
Thread — 4 stroke in a pro chassis? Thread Starter — m1kflyingtiger Forum — Polaris: Pro-Ride Replies — 18 Last Post — 05-04-2013 07:15 AM
Thread — torque stops for the 2 stroke sleds coming soon, here are the 4 stroke ones Thread Starter — catf1000s/p Forum — Arctic Cat: Proclimb M Replies — 16 Last Post — 05-23-2012 11:23 AM
Thread — Anyone have a 125 2 stroke or 250 two stroke for sale in Idaho? Thread Starter — rmk 700 Forum — ATV/Motorcycle (Swapmeet) Replies — 1 Last Post — 04-07-2011 12:13 PM
Thread — 2011 Sno Pro 4 stroke??? Thread Starter — oldcrow Forum — Arctic Cat: M Series Replies — 5 Last Post — 02-26-2010 08:00 PM
no new posts
