Will Polaris belt drive fit 11-12 Pro jackshaft?
P
Peevo
96
54
18
Sweden
Can't find out if it's possible or not? Reason I need to know is because of a broken bearing on my -13 Pro that I just sold. Have found some jack shafts from chain case sleds. A brand new here in Sweden is ridicilous pricey.
Robbie
472
373
No, the brake is different as is the length.
LoudHandle
3,900
2,775
Valdez, AK
Actually it will work if you make a spacer ( or stack the washers used to space out the driven clutch) to take up the extra length.
Minimum length of the spacer is 1 5/16" or 33-34 mm. The spacer will need to go outboard of the sprocket and under the clamping washer that is under the bolt head.
I have a few of both styles sitting here so I measured the difference in spline length.
Your other option is to have a machinist chuck up the '11-'12 shaft and shorten it and re center drill and tap it for the bolt. As the factory did not drill / tap it deep enough to shorten enough, otherwise.
