7
Its a 144". I can't remove the extensions, because the previous owner, who did all the modifications, WELDED THE DAMN EXTENSIONS!
I had 2 Srxs I gave up on the pro action skids and I mounted Doo SC10 3s in there. It made it a whole new sled and cost next to nothing. If I were to do it today I'd use a Cat skid.
M5
Also, I am running 19 / 40 gears and mine will pull your arms out up to about 65 mph then it stops. But that is what i want. I want bottom end grunt. I do not need to go 100 mph down the trail on a mountain sled.
Hope you all had a good summer. Took it out for a ride to dial it in. Would I be able to adapt the suspension a little by moving just the front mount vertical, therefore lowering the approach angle? Or would that totally screw up the suspension? Thoughts?
