T
Last year I finished up the 440 sno pro turbo sled with good results. Now its time to tackle the renegade carb conversion. The turbo is a garrett gt3582r with a stainless v band housing.
How difficult is it to convert a 1K to carbs?
It looks like you're using round slide carbs. Any reason if that's the case? I have one sitting on the bench waiting for transplant into an XP and I just widened the 800 carbs. The carb boots off the 800 ZX chassis or REVs work good for this. Most everything else is very easy and minor.
Lookin good man.
Keep in mind the 1K's have 52mm throttle bodies. Running 44-48mm roundslides carbs will still have a good carb signal.
Being a turbo engine, youre probably going to boost reference the bowl of the carb anyway so with the exception of the pilot circuit, who cares about a vacuum signal?
