01 Phaser Engine issue
My buddy has a 01 Phazer Mountain Max that is gving him some trouble. When starting cold it only runs on one cylinder but the second begins to fire after about 30 seconds and runs fine after that until the engine cools again. He has had a complete engine rebuild replaced the coil, plugs, cdi box and still the same issue. Anybody have any ideas?
assuming that the carbs are clean, check the output of the stator. you will need access to a service manual that will give info as to what ohms at a given temperature across specific wires. a good dealer should share this info. easy check, except most readings are spec'd at 68*F. so you need a warm spot for troubleshooting.
stators are a funny item. things will work just fine until certain conditions are met or exceeded, and then they will act up. usually a small frayin the windings.your situation sounds like a stator issue, although rare on that sled. one other thing to consider would be a rodent nest in the pipe or airbox. depending on where you live and where the sled was stored, these are a couple of areas to rule out. who serviced the carbs? try flipping the choke lever on when the sled starts acting up to see if there is a running difference.
