E
Evolution Powersports is proud to announce we have completed our Viper/7000 Turbo Reflash. We have a few options depending upon whos turbo kit is installed. For kits that have low compression pistons or a head shim, we offer a rev limit increase. This makes a HUGE difference in the clutching you can run. We can set the rev limit wherever the customer wants it, but standard is 9750.
The other option we have is a timing reduction & rev limit increase for high compression kits. This will allow approximately 2-3 lbs more boost on the same fuel you are currently running, or reduce your octane requirements. The rev limit is also set at 9750.
The Viper/7000 engine makes approximately 1.5 hp per 100 rpms over the stock rev limit. This means you will make more power at the same boost just by running more rpms.
Prices will be up on our website shortly.
