1
I would like to see a little higher personally like 97 octaine if you want to run the 13.6 domes. I don't want to tell you it will run perfect and it does'nt . The 13.6 runs no problems at 5-10 k all day long I am just affraid that when the air is 0 degrees and 1000 ft it may not be enought octaine. If you run the 12.5 no problems pump 91
Which head will work the best then in Revy?
12.5 @ 8000 feet with 91 octane or 13.6 @ 8000 feet with 97 octane (more octane than needed at elevation but required due to low elevation at the parking lot).
The 13.6 head will deffinatly be the best if you will run the 97 octaine.
