Whats the trick? (Primary Clutch separating)
smileyz
156
11
18
Lehi, Utah
Okay it wasn't to hard using a puller to get the Primary clutch out of the sled. But I can't get the damn thing to separate.
I've tried leaving the puller in lifting it off the work bench and hitting the puller with a hammer with no luck.
Any suggestions or tricks to get the sheaves to separate?
Thanks,
Mike K.
winter brew
4,332
LakeTapps, Wa.
Just hit it harder, or slam the puller head against a concrete floor (clutch upside down of course).....it will go.
smileyz
156
11
18
Lehi, Utah
Already tried the upside down on the concrete as well with no luck. Even tried holding it up while a buddy smacked the puller with a hammer it just doesn't want to separate.
Thanks for the responce winter brew...
L8Rz,
Mike K.
Skidooguy
30
7
8
Central Washington
What has worked for me is to place the clutch horizontal on the floor on a piece of wood, put your foot between the halves of the clutch and use your foot as a wedge as you hit on the bolt. Has worked every time for me.
smileyz
156
11
18
Lehi, Utah
Thanks for all the suggestions. I ended up using a heat gun and then smacking it on the concrete again and it finaly gave in to all the abuse...
L8Rz,
Mike K.
