If you are going to shim the needles, your best value is to contact EGT (Exhaust Gas Technologies) and order their needle shim kit. Order the triple kit so in case you drop and lose one you will have an extra shim. The shims through Doo are way over priced cause you can almost buy the whole kit from EGT for the price of one shim through Doo. I shimmed mine .030 and the tab holding the needle in seemed fine. It is a challenge to say the least to get to the inside carb without dropping the white plastic shim. I dropped mine inside the carb and ended up taking the entire carb rack out. I was not happy to say the least.
