So it has begun. M5 stripped down to bare bones. I removed the 141" tunnel extension and installed a 153" extension from my '07 1000. Removed engine, wiring, hoses and cables from F-7. So far it looks like everything will be fairly easy. The pto side mounting plate even bolts right up. Thermostat outlet neck is different diameter, but the parts swapped over. I looked the gas tank over for the spot where a fuel pump could be installed. Not there. There is a bulge where the fuel line attaches. I could probably make it work, but I have the fuel tank from my M1000, so no point in making things complicated.
The oil pump check valves on F-7 engine were leaking, now is the time to change those. The upper a-arm bushings on the M-5 were completely worn out. They are nylon?! Must have been a first year thing. Shocks are off getting rebuilt and re-valved. Diamond drive has been taken apart, inspected and assembled with fresh oil. 3 wire voltage regulator is on order.
So far this is a no-brainer and looks like it will work out well. As soon as I get the check valves I will get the engine set in place and start wiring and plumbing. That may be where the problems start. Something is bound to be difficult, so far it is just too simple.
