MDS Clutching help
E
edavis0202
788
422
Colorado
Looking for some help on MDS Clutching. I was suggested to run 64gram BB weights, but I have MDS weights now and hoping to stick with them.
Does anyone know what a MDS setup would be comparable to 64 BB
Will be riding 9-12ft and shooting for 8300-8400RPM.
D
dub
727
61
Moxee WA
You should be okay with the hex head cap screw and lock washer in the tip.
I add a set screw to the middle hole for up to 7K elevation...
wellfed777
2,226
412
83
Oregon
i'll pm you his #
the base weight is variable and then bults,screws and washers on top of that
my guess is you'll be drilled allen and washer in the tip (just a guess)
my base weight is 62.8g
azzkicker
423
33
What have you done to pull that weight at that elevation?You might get some input on here.I was 64 BB and Im 67 MDS now but at 3-6k
E
edavis0202
788
422
Colorado
SLP Pipe/Can, RKT Drop In kit, PCV w/ SLP Stage 4 mapping.
They have a different clutch setup, but I want to use what I have now.
MDS Weights currently at 66.4grams
Purple/Black Secondary
Green/Black Primary
Its Jeremy's setup at Guys Outdoor Equipment (minus clutching), looks like it rips
http://www.youtube.com/watch?v=bjOI7FK2V4M&feature=player_embedded
