Oil Injection delete/elimination... ?
L
Dec 7, 2007
174
7
SWEDEN
I have done a Oil Injection delete/elimination on wife's Crossfire since the oil pump not working satisfactory.
But something does not seems to be ok when the Engine is running.
I have filled the space where the water pump shaft is with oil and mounted a small oil reservoir instead of the large bulky one.
But as soon as I start the engine, It starts to consume oil from the oil reservoir and the level drops
and the engine smoke like crazy.
Is not the space where the water pump's shaft sits sealed against the crankcases ?
Or do the crank have a bad seal against the waterpump shaft space so the oil just leaks through ?
<!-- / message -->
kiliki
13,213
2,398
Nampa, Idaho
each side has a ring with a split in it and the oil will pass.
use the BDX oil delete and just put 10 pumps of grease in it every 500 miles or so. I cut a hole in the belly pan and use the rubber plug from the center of the intake plenum mounted under the hood and cover the hole under the hood with heat tape. lay it on the side take the plug out pull the bolt from the center of the case and add grease, put plug and bolt back it. takes 5 min
L
Dec 7, 2007
174
7
SWEDEN
Each side has a ring with a split in it and the oil will pass.
I do not understand what you mean, can you develop your answer ? :face-icon-small-dis
According to the exploded view, there is a crank seal on each side of the water pump shaft.
This should mean that the space is sealed to the respective crankcase.
# 20 ( Middle Crank Seal , # 3005-597 )
L
Dec 7, 2007
174
7
SWEDEN
This is what I have done....
I have used a oil injection delete bottle from Rotax ( very small ).
I have connected one hose to the block off plate,
and the other one to the lowest point under the engine.
The pictures below are quite self-explanatory.
FYI: The Pictures are not from wife's sled !!
I just posted them so you all got an idea what I have done.
Thunder101
1,303
191
I have not had any troubles deleting the oil pump on these engines (800cc). I run 32:1 and ride it. Don’t bother with grease or a drip set up. Just ride it. It will be fine, oil gets in there !
kiliki
13,213
2,398
Nampa, Idaho
look at your #20 it is metal and number 18 rides around it. so not a complete seal.
you can do as thunder101 states but i add the grease just for extra lube
kiliki
13,213
2,398
Nampa, Idaho
