N
Anyone know how much boost the rx1 mcx kit fuel system is good for?
14-17?
14-17?
those carb turbos sleds can run pretty high boost. you should be good till 19lbs, the only thing is that your not going to gain much more power anything above 15 lbs because you are reaching the max output of the turbo. you could upgrade to the 19T if you wanted. Then you would make insane power at high boost.
