Upgrade to Premium
Arctic Cat: Proclimb M 2012 and beyond
Reply
  #1
Old 03-05-2019, 05:37 AM
therookie therookie is offline
Currently: Not set.
therookie is an unknown quantity at this point
Default Throttle safety switch
I am on a trip in the backcountry, having small bog off idle, what color wire is the TSS. I was going to take throttle block apart and unplug, but afraid to mess up washer for throttle pin. Not close to dealer.
I do have and use a tether, and understand the purpose of safety switch.
Thinking i could cut wire outside of throttle block tape it up. If it doesnt work i will solder back when i get back to my house.
Sent from my SM-G950W using Tapatalk
Rate this post: Yes | No
  #2
Old 03-05-2019, 07:39 AM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
What year? Most just have a small black 2 wire plug in the block just behind it. You need a small torque screw set to remove the white L retaining cover inside the block tho
  #3
Old 03-05-2019, 08:44 AM
summ8rmk's Avatar
summ8rmk summ8rmk is online now
Currently: Snow angels in dog parks
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
Default
T8 driver for the tiny screw
Polcat
  #4
Old 03-05-2019, 09:02 AM
MI1M600EFI's Avatar
MI1M600EFI MI1M600EFI is offline
Currently: Ready To Ride!!
MI1M600EFI has a reputation beyond reputeMI1M600EFI has a reputation beyond reputeMI1M600EFI has a reputation beyond reputeMI1M600EFI has a reputation beyond reputeMI1M600EFI has a reputation beyond reputeMI1M600EFI has a reputation beyond reputeMI1M600EFI has a reputation beyond reputeMI1M600EFI has a reputation beyond reputeMI1M600EFI has a reputation beyond reputeMI1M600EFI has a reputation beyond reputeMI1M600EFI has a reputation beyond repute
Default
Odds are it's not your TSS. Check your belt deflection. When the belt wears and gets narrower, it "gears up" the launch, like trying to take off in 2nd gear. That causes an occasional off idle bog, mostly from a stop. My M8 does it worse if I just rode it a bit hard and then let it sit for a half a second and try to take off again.
I blamed my bog on the TSS, then the SLP can, then low fuel pressure, then a sticking oil pump... In the end, the deflection was excessive and I adjusted it and the bog was instantly gone.
Whod'a thunk??
__________________
'09 M8 Sno Pro 153"
'02 Z440 Sno Pro - Wife's sled, my project...
New to the fleet:
'09 M8 HCR 153 Boondocker Turbo
  #5
Old 03-05-2019, 04:09 PM
Currently: Not set.
Default
Thanks for the replys guys, my sled is a 2017 XF8000 High Country 153".
Put 100 miles on sled today with stock can and working great except i still have the bog for initial start off engagment is at 3500 rpm.
I have the wiring diagram it shows
A microswitch/ rps with a black/white and black/blue. I think this is the TSS.
It also shows a shift switch with a wht/vlt and black wires but i think this is the reverse switch.
I did adjust belt at beginning of trip, I think its tight enough. But i can another look
I would like to rule out the TSS without taking the throttle block apart. If i can finish my trip i will take it apart in my garage. I dont want to mess up the washer for the throttle pin and not be able to find one.
  #6
Old 03-05-2019, 04:17 PM
grandpaj grandpaj is offline
Currently: Not set.
grandpaj has a reputation beyond reputegrandpaj has a reputation beyond reputegrandpaj has a reputation beyond reputegrandpaj has a reputation beyond reputegrandpaj has a reputation beyond reputegrandpaj has a reputation beyond reputegrandpaj has a reputation beyond reputegrandpaj has a reputation beyond reputegrandpaj has a reputation beyond reputegrandpaj has a reputation beyond reputegrandpaj has a reputation beyond repute
Default wiring
The bl/wh wire and bl/blue are the switch. If you cut/remove the bl/wh it just eliminates the tss, if you do both or the bl/blue then you kill switch seisies to function. cut the black white and all should be good
  #7
Old 03-06-2019, 12:37 AM
Storskogen Storskogen is offline
Currently: Not set.
Storskogen has a reputation beyond reputeStorskogen has a reputation beyond reputeStorskogen has a reputation beyond reputeStorskogen has a reputation beyond reputeStorskogen has a reputation beyond reputeStorskogen has a reputation beyond reputeStorskogen has a reputation beyond reputeStorskogen has a reputation beyond reputeStorskogen has a reputation beyond reputeStorskogen has a reputation beyond reputeStorskogen has a reputation beyond repute
Default
You could also try to adjust the wire so that you have a bigger gap to the TSS. There are hundreds of "solutions" to the bog, but none that seems to work for everyone. I tried to disconnect the switch, more fuel, less fuel (PCV, low rpm fuel) but still bogging, moved the airtempsensor last summer but due to lack of snow it wont leve the garage this season
M800 -13, Speedwerx full exhaust, PCV. BC WT 660T -06
__________________
M800 Ltd -13, Speedwerx full exhaust, PC V, AC full vented panels
  #8
Old 04-03-2019, 01:58 AM
mtncat600 mtncat600 is offline
Currently: Not set.
Basic Member
mtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond repute
Default
have 2 2017 m8000 sno pros bog before engagement
both doing same thing
  #9
Old 04-03-2019, 03:18 PM
Duff Duff is offline
Currently: Not set.
Duff has a reputation beyond reputeDuff has a reputation beyond reputeDuff has a reputation beyond reputeDuff has a reputation beyond reputeDuff has a reputation beyond reputeDuff has a reputation beyond reputeDuff has a reputation beyond reputeDuff has a reputation beyond reputeDuff has a reputation beyond reputeDuff has a reputation beyond reputeDuff has a reputation beyond repute
Default
The bog on my '17 went away this year. I added a Speedwerx stage 3 and an SSI intake along with relocating the air temp sensor. Not sure which one did it or it was a combination of them.
  #10
Old 04-03-2019, 08:08 PM
Badv2 Badv2 is offline
Currently: Not set.
Basic Member
Badv2 is an unknown quantity at this point
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — What happens to the throttle safety switch when using an aftermarket throttle block? Thread Starter — sledr900 Forum — Polaris: Pro-Ride Replies — 2 Last Post — 01-22-2012 09:28 PM
Thread — Need help with bypassing throttle safety switch to change my throttle block Thread Starter — AK Soul Forum — Polaris: Pro-Ride Replies — 2 Last Post — 11-24-2010 08:38 AM
Thread — Video: Bypassing the Throttle safety Switch and Kill switch on 1990's Cats Thread Starter — Blaine Forum — Arctic Cat: Powder Special and older Replies — 0 Last Post — 08-24-2010 10:15 PM
Thread — Video: Bypassing the Throttle safety Switch and Kill switch on 1990's Cats Thread Starter — Blaine Forum — Arctic Cat Replies — 0 Last Post — 08-24-2010 10:13 PM
Thread — left hand throttle, and throttle safety switch Thread Starter — noturn Forum — Polaris Replies — 4 Last Post — 03-11-2010 08:16 PM
no new posts
