2019 BDX PROLITE OMEGA SNOW CHECK
BD-Xtreme
267
WE WILL BE OFFERING THE NEW PROLITE OMEGA WITH THREE DIFFERENT POWER OPTIONS THIS YEAR!!
THE 900 PROMAX BIG BORE IS THE LIGHTEST VERSION WHICH IS 40 LBS LIGHTER THAN A STOCK ALPHA!!
WE ALSO OFFER THE NEW OMEGA WITH THE SILBER TURBO KIT OR THE BOONDOCKER SIDEKICK TURBO!!
EXCITING NEWS!! THE TURBO MODELS ARE ABOUT 20 LBS LIGHTER THAN STOCK.
BELOW IS SOME INFO ON THEM AND A LINK.
http://www.bd-xtreme.com/index.php?id_category=210&controller=category
BDX just took the new Arctic Cat Alpha to the new level!! Why buy an Alpha when you know you really want and need the new BDX OMEGA!!
XTREMELY LIGHT WEIGHT - 40 LBS LIGHTER THAN THE ALPHA!!
XTREMELY POWERFULL - 200 HP ON PUMP GAS
XTREMELY LIKE NO OTHER
CHASSIS UPGRADES:
BDX Pro Running Boards
BDX ProVision Bumper with LED Lights
BDX ProMax Cold Air Intake Hood
BDX Lightweight Chaincase Cover
BDX Lightweight Oil Tank
BDX Lightweight and Larger Capacity Gas Tank (available in black or clear)
BDX Prolite Flat Top Seat with Rear Storage
BDX Prolite Spindles and A Arms
SLP Mohawk Ski's (any color you want)
Custom Wrap to your liking
POWER:
SSI 900CC PROMAX OMEGA BIG BORE KIT, with billet head kit, aluminum exhaust valves, forged pistons, fully ported and renicasil plated.
SSI Stainless Y pipe
SSI Pipe, Ceramic Coated and Polished
SSI TITANIUM Xtremely lightweight Big Bore Muffler
SSI 55mm Throttle Bodies
Boyesen Large Inlet Reed Valves
SSI ProShift Mountain Series Clutch Kit
PowerCommander Fuel Controller
ORDER YOURS NOW WITH $1500 DOWN BY APRIL 18TH!!
FROM THE FACTORY:
-NEW SINGLE I BEAM REAR SUSPENSION
-NEXT GEN 3 INCH POWERCLAW TRACK 3.5" PITCH 165" LENGTH
-DSI FUEL INJECTION
-TEAM CLUTCHES WITH AUTOMATIC ADJUSTING BELT DEFLECTION
-FOX QS3 SHOCKS
-NEW HANDLEBAR CONTROLS AND SWITCHES
-NEW STEALTH MASTER CYLINDER AND BRAKE LEVER
-ICE SCRATCHERS
-DROPPED CHAINCASE
2019 Omega snow check b.png 2019 alpha track in action.jpg 950 dsi motor b.jpg 2019 alpa skid side.jpg oil tank 2018 with cover.jpg SIGN 20081 pro boards final.jpg throttle bodies 55mm 2.jpg SSI 12-106T.jpg
BD-Xtreme
267
you show a ssi 900 and 950 in the info, thinking you made a typo in the top half...
We went with a 900 cc kit, 90.5 mm. We bored out several cylinders to the 950, but our last batch of production cylinders would bore through into the fuel injector port. That is a lot of extra work with welding and re-machining. So we decided to make it a 900cc package, which still rips!! Plus its a 900cc Race legal size package for Racers.
d1100t
1,814
400
83
Saskatchewan Canada
Is there anyway of using a longer stroke with these cases?
Wouldn't a few extra MM of stroke make these motors stronger yet?
BD-Xtreme
267
We can always do the 900 big bore and turbo kit too. That is in the works as well.
d1100t
1,814
400
83
Saskatchewan Canada
Stroke
That really didn't answer my question???
I haven't came across any info on anyone doing any work with longer strokes in these motors is why I'm asking.
89sandman
4,897
2,072
southern oregon
Could it be that AC has already done this and just putting miles on it to make sure it is durable and tuned before release ;) Sure they are smart enough not to bite the hand that feeds them...
madmax
3,146
Salt lake city
I’d bet there’s not enough room in the case for a longer stroke. Plus the expense would put you into “why” category and very few people would opt to do it.
eldereldo
151
82
Longer stroke = more vibration at the same RPM. Just ask Doo how hard it is to deal with that :face-icon-small-hap. Also means new connecting rods, probably needs the ports moved in the cylinder. Might require a new cylinder depending on how close the piston is running to the top right now.
d1100t
1,814
400
83
Saskatchewan Canada
Power
I'd agree.
I'm hopefully cat has a 900cc or bigger motor in the works!
