Bill is your skid stock? Are you running the stock front shocks. I’m wondering if what you are experiencing is coming from the front end. The stock front shocks are really soft and the springs wear out and lose what little bounce they have pretty quick. Using a shock with a real spring or a Fox air helps the Doo chasssis a lot. I usually run quite a bit of rebound damping too to match the added spring pressure. I really notice how much the front shocks help the handling in really deep snow or crusty crappy snow.
The Toms kit comes with a solid front arm as part of the deal. He eliminates the torsion springs and when you do that the skid flexes WAY more side to side with no spring support on the outside rails.
Those t-motion delete plastic washers can’t really do much. If you’ve installed them have a buddy pull the sled up on your garage floor and watch how much “motion” your t-motion still has.
