LOL. I see in the video the enthusiasm with the design leaders LOL. Maybe Polaris and Doo have Yoga in the morning, but I see a little more passion from their employees.
Never ran my sled in stock positions. Lowered the front by moving the middle shock in the skid for more travel and rear in the lower hole with a sag built in. Much better in powder. Tried to tell people but it is hard to change old opinions.
After a season like this, IMO, it needs some more drop in the front. 3/4" is too much with the stock rails, unless you suck in the limiter strap some more.
What we really need is new rails with the lower shock mount moved forward 5/8"to allow the existing limiter strap to be fully used in the upper hole and a full inch drop in the front too. This would need a curve built into the front of the rail (like every other modern skid built today) to eliminate the power robbing front rail pressure in a bumpy climb.
This set-up would actually make the limiter strap useful. Fully out for early season and one hole tight for spring.
While your at modernizing your skid to rider forward Cat, give us the correct springs in the skid to allow the rider forward weight to transfer easier. When you took away the well thought out TCL link in the rear arm you took away most of our transfer. Every Cat since has felt front heavy and this one is the worst.
That wimpy 110 lb spring in the middle needs the rear to be preloaded to at least 300 lbs just to hold the sled up without a rider on board. Get your s**t together LOL.
Here let me help you LOL. Do the rail change and front arm relocate. Install a 150 or 160 lb spring with zero preload in the middle (or if you want to spend the extra dough use a dual spring set-up; 325 tender, 200 main, .95 cross over spacing, zero preload). Install the 210 lb spring from you 2011 M in the rear and set the preload to 200 to 225 lbs.
Your finished. that's all you godda do to the PC to make it feel light in the front and you get the bonus of lift in the deep. Oh, and good pick on the 38" front end and more steering, just finish it with less lock to lock on the bars please.
I don't think I'm all that LOL. I just thought I would put out what I have done to mine this season in a funny way, and it works very well and I truly hope AC would give this out to every one else for 2013 instead of just half way.
