D
So does anyone know who is making these "out of spec" clutches? My understanding is that Team is making the secondary but no one can tell me who makes the primary.
Another thing to check is your rail tips. They are wearing fast and a friend of mine was blowing belts and it was the rails (tips gone) pressing into the track when in powder. By the time we caught the problem the track was bad. Dealer had two other 13's with tracks gone with low miles. I checked mine at 150 miles and tips were almost gone when I did my update. I think I will be moving mine to top back hole and adding rear bracket, might keep it from wheelieing on steep climbs too.
So far what I have learned.
I am paying too much for belts and will go after market.
I had already done/tried all of the cleaning and alignment tips.
I just installed the 20t (and SLP) Have not rode yet to see if the gearing will help.
Interesting topic on out of spec clutches. Wife has same Sled same set up no issues yet. I wll swap out secondary with her to night to see if issues moves to her sled. (don't tell her:face-icon-small-win)
Hope I don't have to send clutches away to be balanced (or by Team)
It is not the rail tips have had anti stabs on since day one,
Off topic reduce your rear shock pressure if you are having a wheeling problems
i cut open a plastic gnc bottle, molded it will some heat, and made a cover for my disc brake so the mist dosen't fly off the disc onto the sec. it dropped my sec clutch temps by 40 deg
I have a 13 m8 153 le
First ride great lol.
Second ride I blew a chain At 60 miles. Top gear was way out.
3rd ride blew the stock belt. Belt wear said the driven has to go In. Clutch tool said I needed to add 90 tho shim.
Now at 156 miles an 3 belts blown.
2 belts tore and the other exploded. Allinment is perfect.
I'm at a loss for words. I cannot afford to ride my sled.
Im Seriously going to look at how I can return this pile to arctic cat.
My sled has to be a lemon.
What do I do?
If your counting money this is the wrong hobby for you...................:face-icon-small-sho:jaw:
Also my motor and secondary wobble around in there something fierce.
I think the issue is movement.
