how do i keep everything straight doing this? i dont want smaller drivers for bigger paddles and i have a 1 7/8" longer chaincase on the shelf. i have stripped the entire sled down to the tunnel, bulkhead, and belly pan.
im thinking if i can just get my jackshaft straight and secure ill slip the case on and mark everything out. but how do i secure it?
maby i can run a center line down the tunnel, run my square between the line and the jack shaft. then use my speed square for the height of the shaft, or make some kind of spacer, yeh a spacer! that way i can clamp it secure against the spacer while i mark everything else out.
now how would i go about the other side, speedo side track shaft? ooh, maby just run the square inside the tunnel wall against the drivers. then measure the distance from the top of the tunnel th the shaft?
any one have better ideas??
