I think there is a difference on one of the mounting holes on the front side of the case. The 01 and 02 mountain cats had the slight drop and roll and the chaincases had two different holes on the front bracket to fit either the mountain or the regular bulkhead. The older chaincases do not have the two holes but all the other holes in them bolt up the same. I would either not worry about leaving one bolt out or would just drill the hole through into the bulkhead and put a nut on the bolt instead of using the threaded insert. Incidentally the older chaincase will fit right on the 1M bulkhead.
