lighting coils???
U
Nov 24, 2010
15
10
03/04 King Kat no lights and I cannnot seem to find any power to speak of to run my Raepack. Which wires at what plug should i be looking for voltage? Ease of replacing the stator? Sleds runs fine but assume lighting coil will be attatched to the stator.
Idcatman1
125
Ashton, Idaho
Lighting coil
The lighting coil is on the stator but it is all one unit, you can't just replace lighting coil. My suggestion is to check the voltage regulator first. It is an aluminum box bolted to the right footwell. If it is bad you will lose all lights, handwarmers and the tach, abut the sled will still run. There should be a plug under your dash that the oil lever sender plugs into. It will have an extra connection with a yellow and a brown wire. You can get 12v AC from the yellow and the brown is ground.
Good luck
