W
Supposedly there is a new flash that is supposed to make the silber alpha run perfect. Local dealer is testing it tomorrow to make sure before i flash mine.
Me too. Not going to do it unless it's right this time.
I have the most current flash and do not have any real big gripes with it. It could be a hair cleaner on the bottom but mine does not bog. Waiting for some on snow reports before I’d change mine.
The most current flash as of 2/12/19? If it was the one before that and you know how a properly tuned turbo can run, you’d have gripes.
On my 18, after the 10 mile Road back to the truck will die out if I put it in reverse.
Ideas?
take it to the dealer... its covered at this point.On my 18, after the 10 mile Road back to the truck will die out if I put it in reverse.
Ideas?
I would stop putting it in reverse.
They'd really appreciate the turbo on it I'm sure... Plus there's no warranty after a year. It's clearly an issue when the engine is hot ish, but think it has to do with the turbo program as well.
And why the smart-ass comments don't put it in reverse?
You suggesting that I drag it off the deck?
Everyone complaining about the tune not being right with a hesitation which is still rideable. I bring up a legit problem that I'm having, and get stupid replies.
The engine dies out... I guess I can make engine noises, bounce around on the sled, and pretend to be backing up.
10-19-2018 is when it was flashed.
I do have the reflash cable too.
Wanted to say that myself many times, thank you!
Ideas?
Guys that have turned the boost up to 8-9 psi are you running 50%av/50%91? Also does anyone have a baseline idea of what 1 turn on the wastegate actuator rod is worth as far as psi? Thinking of turning mine up a bit it’s at 6 and runs real well, but I’m interested in more lol.
