H
Verify, the pipe to hose fitting that connects your vacuum hose to the solenoid is tight.
We have the 2012 600 and always ran the sled with a jumper hose between the valves. Just leave the solenoid plugged in. Back to back testing showed the sled ran better.What are symptoms of the Power Valve Solenoid being bad? Read on how to bypass the issue but I'd rather just fix it. Still fighting an issue I thought was solved with a bad TPS but nope. Had a couple issues last year where it lost a bit of power, took apart Power Valve Solenoid and cleaned up and was good. Now nothing seems to work, only pull 6800 rpm at WOT. Cleaned, checked, filters, fuel pressure, clutching, everything. Any help appreciated, thanks.
