Here is a step by step for the install of the new rear scissor brackets. I got my set from Rooster built, $70 including the shipping.
First off I measured the starting height of the sled with the suspension all the way up.
Next you want to use a ratchet strap, attatch to both sides of the lower rear scissor while going around the rear axle. Tighten the strap up snug and remove the nut off the end of the lower bolt.
The bolt was gummed up so I used a set of Vise Grips to twist the bolt loose. Pull the bolt all the way out.
Be careful of the inner washers, they will try to fall under the sled and hide.
Tighten the ratchet strap to pull the rear scissor arm back and install the new scissor brackets with the inculded bolts.
Now its time to reinstall the bolt, this is the hardest part because of the two washers on the inside of the rails.
Tighten it all back up and here is what you got. It certainly changes the angle of the lower scissor and stiffens up the rear suspension.
By my measurement you loose just under 2 inches of standing height. But when you get on the sled there in not nearly the sag. Hope this helps! :beer;
