P
I have a 02 edge with a 06 600 HO carbed motor in it and have been looking all over this forum about turboing sleds. I am going to do it to mine and was wondering if you guys could help me out. I am going to use a Garrett t25. I know that I need some sort of fuel pump that will pump fuel under boost. I also know that I need to change compression and or timing as well. The last thing that I know is that you have to make a setup to oil the turbo too.
What do I use for a fuel setup, what heads can or should I run and with what device for controling the timing, and what is the best boost levels to run on pump gas? Will an EGT be a good way to watch my tuning or a wideband? I am at sea level and that is where I will be tuning it as well.
Thanks for the help in advance and I cant wait to start this project!
