05 M-7 limited w/w.o. fresh BMP900
I Snowchecked this sled new in 05 and it has the following mods.
BMP 900 kit included:
Crank saver, BMP fuel regulator, bd box, crank true and weld, case porting, BMP fatazz single pipe, BMP y-pipe, BMP can, sno-pro airbox.
Dyno tuned at BMP @ 178hp I have the sheets.
Simmions ski's
HRP front arm relocation bracket
straightend attack 20 with ice screws, works very well. It does show some wear.
Ice nitrous system.
MoFlo front vents
Cat head hood vent
side panel vents
Digitron 2 window egt
2inch rox riser
MT fit hood that does have some cracks
Stock orange hood is in new condition.
CPC secondary kit
CPC adj primary set-up
I just put 2 new pistons, and had to get a cylinder re niked because of my own screw up, wrong fuel.
This is a high elevation pump gas set up, but I have always mixed a couple of gallons of race fuel and premium and never had a problem and it does give you more protection.
The sled has been kept in Cooke City every winter and I only get out there a few times a year to ride so that is the reason for the mileage. Before the diamond drive/speedo update came out my speedo quit for 2 weeks before I got it into Cooke City Motorsports to get it fixed so it has a couple hundred more miles than what the od reads.
I can get the sled out to Cooke for you ready to ride!
I'm asking $6,900 with motor and I will seperate the sled and motor.
The sled ready to ride full of fluids weighed 554#
http://s720.photobucket.com/albums/ww207/m7limited/
Simmions ski's
Ice nitrous system.
MoFlo front vents
Cat head hood vent
side panel vents
2inch rox riser
CPC secondary kit
