I
What happened to all the talk of the factory turbo 2-stroke? That was the whole point of the 850 I thought.
Note: this_feature_currently_may_not_be_available_in_some_browsers
Refinements is what I anticipate... but no changes in design.
Good bracing and bumpers that tie it all together...tunnel/drivetrain bracing.... all in the aftermarket.
This chassis does not seem any less durable than the past...and is the lightest to date... it will be up to the customers to add weight to the sled with more bracing etc...
Clutching will need to be addressed... and from what I hear, both BRP and the aftermarket are hard at work for this.
This is a reasonable expectation by all IMO.
1. Better snow evacuation at front of boards
2. Raise fuel cap area to keep ice and snow buildup out of fuel tank, fuel Cap was frozen solid every fuel up so far
3. Redesign high beam and grip heater controls, mine have been frozen solid all winter
4. Redesign goggle box area to keep snow build up down, snow falls into it keeping goggles fogged up
5. Needs more power to dust the axys, very disapointing to get dusted by an axys
6. Somebody design a hard plastic trunk to fix the ugly non e-start batteryless area
7. Lower the seat slightly
Are you Doo boys reading this? I want the G4 to succeed too (good for the sport) but to get beat by a sled 50 cc smaller and 15 hp less, that is downright embarrassing. The other points are good too.
Lol. The 850 is succeeding and in my opinion, dominating. I have yet to see an axys dust an 850. If you compare completely stock sleds, it comes down to who's the better rider, the axys rider has to be a better rider than the 850 rider to keep up. People can't seem to believe how good it goes until they see it with their own eyes.
If your getting dusted by an axis,,, your clutching is Fawked.
Just to clarify
165X 3"
@ 120 miles 60% breakin left 1000 feet elevation, black secondary, pin weight 23grams "goodwin kit" max rpm 8100
drag racing on the trail
A 2015 174 walked away from me from a rolling start several times
@ 280 miles 6% break-in left snowy's 8000k'ish, black secondary, 20gram pin weight max rpm 8100 drag racing on trail
A 2016 163 axys neck and neck from dead stop till 50-60 then walked away from me
My max mph recall 77
I spend most of my time in tight tree's
So no real climbing to compare these sleds
Snow was very good in snowy's couple weeks back, anything steep we stayed off of.
Still on original belt, deflection set perfectly, primary looks like it was on fire at sometime... clutches after 1 week of riding look like they are 2 years old..
Primary clutch issues would be my best guess?
Had to tighten chain almost every ride
"Clunk"
On a HUGE positive
This sled is VERY easy to ride all day long, no fatigue at all even after a week of riding hard!
Steering effort WAY easier than Pro and Axys.
It goes anywhere! Climbing power and control are Simply awesome!
Started first pull everytime!!
No boging ever!!
Pro's and axys barely started on cold mornings, and were plagued with bogging and cutting out all week..
It took a beating! My front bumper and A-arms have a coating of bark!
Wedged inbetween 2 big trees..
Running board should have cracked but didnt.
Hit a fence post full throttle on a climb
Over the bars.. a-arm and skid plate hit,
No damage
Hit quite a few boulders under the snow..
No damage..
I'm that guy that finds all the hidden things and destroys A-arms and bulkheads..
So far so good for me!
Sorry for all the peeps out there with issues!
Hang in there!
If youre getting dusted by an axys, you need much more than a few more ponies. You need to book an extended trip with brett rasmussen or carl schuster. They are not even close. But , hey on lake maybe the axys is right there. In the mountains. ....on climbs.....its incomparable. ...imo...what ive witnessed firsthand...for about 450 miles..
