You can still run a trail along side the brake and case. You rarely use it but will work if it there when needed.
:juggle:
Doesn't work, would still drag where it gets wide
Yes, the most important place to be narrow is at the front of the boards and the belly pan.
gotta disagree.those extreme boards are drawn up by a pro rider who rides wfo.less in back where you dont need it.streamline look.and less crossbars for max flow.
Edit done to the boards to see the result. Note the RMK is wider and will gain a positive angle.
