M
SOLD
Selling my 2008 Supercharged Nytro. Started life as a 40th Anniversary Addition...Running 12 lbs of boost...approx 240 HP. Sled has 3700+- miles. Just did a compression test, 180-185 psi on all 3 cylinders (for reference, Randy Swenson has over 10,000 on his boosted nytro and apex and they still have less than 3% leakdown).
*MPI Stage II Supercharger @ 12 PSI...I run 100LL Av Gas.
*MPI Fresh Air Kit.
*Turbonetics Raptor Blow Off Valve.
*Power Addiction Tunnel (Brand Wursten) with outer running board coolers and Double Pass U Cooler...Brad makes his tunnels out of .090 instead of the .064 of the other tunnel builders...this tunnel is BULLETPROOF!!
*Radiator and Bulkhead cooler delete.
*Under Tunnel Exhaust.
*Timbersled BarkBuster Front with Fox Floats.
*SlyDog PowderHound Ski's.
*Timbersled Mountain Tamer Rear Skid with Ice Age Rails and Fox Floats.
*Mountain Machines 8" Big Wheel Kit.
*162 x 15 x 2.5 Camoplast Challenger Extreme...no missing or torn lugs.
*HyperFax.
*Avid Drivers.
*19T.
*ShockWave Helix.
*Less than 500 miles on new Primary Clutch.
*Trail Tank 10.2 gallon tank.
*Lightweight Battery.
*Raised Seat.
*Diamond S Mesh Hood.
*PowerMadd Pivot and 8" Risers.
*RSI Bars.
*RSI Hi Power Grip Heaters.
*ODI Grips.
*2 Cool Vents (full kit both sides).
*Full extra set of plastic (hood, windshield, console, tank cover,side panels).
*Also comes with the stock headlight and mounting hardware if you want to return to running stock hood.
This sled has over $30K invested. Similar sleds are selling for $16-20K.
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
*MPI Fresh Air Kit.
*HyperFax.
*Avid Drivers.
*19T.
*ShockWave Helix.
*Raised Seat.
*RSI Bars.
*ODI Grips.
