2012 155" PRO is eating hyfax with deposits on clips
U
Feb 11, 2017
10
2
3
Pretty fresh install of hyfax with only a few rides on it and I see that weirdly there are little mini chunked up pieces of hyfax on every clip as well as a tiny bit of rubber track as well. Anyone have ideas as to why and how to fix? Thanks
Reg2view
2,392
1,600
Beyond track tightness and skid pressure, did you temper them, as in, ride abit and heat them up, then stop and kick enough snow on them until they're cold, a couple times?
kanedog
Undefeated mountain clutching champ of the world.
3,106
3,862
That'd be the aftermath of running on low snow. Cool thing is, you only have to do it once and then you watch for hyfax melting conditions. Don't stress. It's a part of sledding. No biggie.
Sent from my SM-G920W8 using Tapatalk
Scott
Scott Stiegler
69,618
11,737
W Mont
Hyperfax is the one with the graphite infused surface. Those are usually NOT white.
You can tell if the track is aligned by adjusting the track tensioner at the rear idler wheels. Measure the sag about halfway up the rails. Should be equal. should hang down to factory specs...which (if I remember correctly) is 1.5" with 10 pounds of weight hanging on it.
