i have a low end bog on my 2010 m8, when it is sitting there idling it idles at 15-1700 rpm, were as before it would idle 1900-2000. it bogs up untill about 5500-6000 rpm then it runs fine. it is really bad when you are powder turning going down hill, it is like it is loading up (gettin to much fuel) i checked my plugs and wires, disconnected my tss and nothing changed. i noticed that i used alot of oil on my last ride out, i used almost a litre of oil to half a tank of fuel, i remember reading a post were someone had there oil pump sticking, i used the search but i can't open the link up for some reason (it was 2009 m8 oil pump sticking). if anyone knows a fix for the oil pump sticking i would appreciate it. is there anything else to look for that could cause the bog.
Thanks Gongshow
Thanks Gongshow
