Upgrade to Premium
Reply
  #1
Old 03-01-2019, 01:26 PM
Frontball Frontball is offline
Currently: Not set.
Frontball is an unknown quantity at this point
Default Fuel Pressure Regulator Bracket Part Number
Hey guys,
I know when I looked before I couldn't find the part number for the little bracket (same shape as a two-bolt exhaust flange) that Ski Doo made for the XM and XP fuel pressure regulator. My sled was taking 4 or 5 times to start after sitting for a day, not starting when slightly tipped on it's side, and hesitating from half throttle to full throttle. My fuel pressure regulator was half way out of the socket like most end up.
It took a lot of digging but the dealership finally found the part in their warranty system. It's "415130050 - FUEL PUMP REGULATOR RETAINER."
Should save someone some time finding it at the dealer, and it only cost about $3.00 CAD. Two washers would also do the trick, but I figured for $3 why waste my time finding them in my mess of a garage.
Here's more information about the problem, not my post: https://www.snowest.com/forum/showthread.php?t=407475
Hope this helps.
Rate this post: Yes | No
The Following 2 Users Say Thank You to Frontball For This Useful Post:
bnorth (03-05-2019), derp (03-01-2019)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Stock fuel pressure regulator vs lower pressure regulator Thread Starter — Octanee Forum — Polaris: TURBO Replies — 3 Last Post — 02-17-2019 12:24 PM
Thread — need part number for 600rr ev solonoid bracket Thread Starter — 827revdog Forum — Polaris: IQR Replies — 2 Last Post — 09-02-2011 12:27 PM
Thread — Fuel pressure Regulator Thread Starter — mn2mtns Forum — Performance/Modified Replies — 0 Last Post — 01-26-2009 03:18 PM
Thread — Fuel pressure regulator Thread Starter — SprayLine Forum — Arctic Cat Replies — 2 Last Post — 01-09-2008 09:39 AM
no new posts
