I
Looks like the 16 is finally what the 12 should have been. Better late than never ..... I guess
--Dont forget, it's not just the front end that changed... the rear skid is changed also...new rails with higher front arm mount position, new front shock with more travel
CO 2.0, what do you prefer more your skinz front end or the 2016 front end?
--snowbike...shmowbike
--make sure you get the 15 or newer skid
--going from 160hp down to maybe 60hp(sea level) tapped out wfo all the time...maintenance on your motor will be mandatory
What pics would serve a purpose? It's a failure with a stock motor... what's to see?
As to oil tank, being that it sits higher in the chassis, if anything it should be "better" (less likely to get a bubble that could cause a problem)
Sucks that a warranty has to be a fight, that's one of my biggest issues with poo, and if the other two are going to be the same way, what differentiates them?
If it's a cold seize it should not be covered. That is operator error. I'd like to see pics.
I've seen at least 3 colds that were not operator error, period. A blanket statement like is kind of silly.
Watching temp, miles in on the trail, cold seize, and is my fault. That's operator error.
Now if you give me full access to all sensors with all gauges I'll take the credit any day and I guaranty I would never have another failure.
Yet if I even add egts. It could void warranty. O but it's my fault, you u obviously have no idea how the stock ecu works and what it controls.
The dealer can check ecu for overheat, and its never been hot. Plus I've given so much info on here so either your clueless or didn't read it.
