http://www.hardcoresledder.com/foru...47-wtf-where-did-catf1000sp-thread-go-22.html
did some more testing today while out riding, running down the lake back and forth, riding in temps of about 50 or so degrees f no more belt and clutch heat, after drag racing the sled on the lake the secondary was only about 100 degrees and primary was 154 degrees. weird to say the least.
I think i may have had belts from a different batch to start the season off and the latest one i got was maybe changed a little or my new set up i am running has fixed the belt problem or like stated above, like i have been saying all season, very low mileage belt this 083, the longer you run them the hotter your clutches get, close to 1000 miles and you should thow them in the trash before they blow.
4" of snow and slush and the sled still blows by a 100 with it being 50 or so degrees out.
Just like i said before, the f8 went right by a xf1100t turbo like nothing on the lake. stock for stock
oh, 3900 miles and have not blown a belt yet, you just have to know when to take them off, sad mileage belt for sure.
I think i might have to give them a sanding and see if they come back to life.
frank
Sounds like you guys are still hard at it.. Great to see the thinking continuing..
I have found a few things out as well..
1) My sled, and a few others, can NOT come into perfect alignment.. The engine is too far to the Mag side and needs to come outward about .070"
So, running with ANY Jackshaft shim washers installed will amplify the offset issue.. With no washers, the aligment is close and "doable"
My sled's engine is slightly cocked to one side.. so I never have true aligment/parrellelism between my 2 clutches.. the **** is slight but still there.. I can not see any easy way to bring this into spec.
The TCL still benefits greatly from being tied down with either a simple strp or White Rads mount set up..
You can not change where your clutch locates (inward) on the JS. The JS bearing in the tCL is fixed/located..AND the secondary shaft is fixed length.. therefore; your MAX inward location is fixed due to these 2 items.. Again, mine is still too far outward with no washers installed (used the Team Tied) makes this offset even a tad worse (.020") so IMO, the engine needs to move to the PTO side (outward).
So, my thoughts are that if you are running ANY JS shim washers, and you have the same alignment as me and several others, then you are causing yourself issues... IF your sled is not set up , in terms of positioning, as mine, then you may be fine..
The 083 and the 084 belt do not work well until they get some time on them, thney will run very hot until they "take form" after that, they seem to work well. The 084 is definitely a stronger blt that will take more abuse.
The Team Tied is a great clutch, The only things I do not like about it over the stock is the weight and the added shaft length.. it is MUCH heavier than the stock clutch and the added shaft length amplifies the offset issue.. floating the tied will also amplify the offset issue.
I suspect the the heavier Tied is cancelling out some resonance on the JS and this could be helping some.. Onc eyou have the TCL tied down, the oscillations are greatly reduced.. Cat is changing the JS for 2013 but not the TCL design..
The Mag notor mount is definitely too soft.. and this is an issue.. this shold be addressed in 2013 build as well..
All in all , with the TCL tied down and the best possible alignment set up, the clutches work very well..
All the talk on TCL "flatness" and what not is great ,but <IMO< the flatness of the TCL is not a player...Just my opinion..
This is a great sled.. and sometimes we a relooking for things to find wrong that are simply not "players".. we can get sidetracked with this "searching"
I am happy with mine and I think you guys would be as well i fyou tried the TCL tie down and get the alignment as good as mechanically possible..
Kelsey
Could you not just machine down the shaft on the clutch to get into alignment, or will the sheaves then hit the TCL.
