Upgrade to Premium
Performance/Modified Discuss modifications for your sled
  #1
Old 06-07-2010, 11:06 AM
go high fast's Avatar
go high fast go high fast is online now
Currently: enjoying every minute of summer
go high fast has a reputation beyond reputego high fast has a reputation beyond reputego high fast has a reputation beyond reputego high fast has a reputation beyond reputego high fast has a reputation beyond reputego high fast has a reputation beyond reputego high fast has a reputation beyond reputego high fast has a reputation beyond reputego high fast has a reputation beyond reputego high fast has a reputation beyond reputego high fast has a reputation beyond repute
Default P85 clutch puller for PSI motor - just the standard polaris clutch puller, right?
having a major wrestling match trying to get clutch off PSI 1085 motor and currently losing.
the puller is based on the clutch right??? A different crank wouldn't require a different puller right???
Thanks guys!!
__________________
see ya at the top!
Rate this post: Yes | No
  #2
Old 06-07-2010, 11:40 AM
NapaMatt's Avatar
NapaMatt NapaMatt is offline
Currently: Stocking shelves, Need Parts??
NapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond repute
Garage
Default
Different CLUTCH Different Puller!!
Yes it will work
Matt
__________________
FOR SALE... SLP Pipe Set For Pro RMK 800... PM. Me for Details BRAND NEW 2013 ASSAULT PIGGY BACK FRONT SHOCKS FOR SALE!! $$650!!! Gas Tank From a 07 Switchback/ Seat Red and Black No tears. Plus fuel lines.
http://www.napaonline.com/
Theye Supply 1-507-533-6610
Auto Parts, Snowmobile, ATV, Truck and Trailer.. and
Shop Local!!
  #3
Old 06-07-2010, 08:28 PM
clutch man clutch man is offline
Currently: dex add up now location La pine or.
clutch man has a reputation beyond reputeclutch man has a reputation beyond reputeclutch man has a reputation beyond reputeclutch man has a reputation beyond reputeclutch man has a reputation beyond reputeclutch man has a reputation beyond reputeclutch man has a reputation beyond reputeclutch man has a reputation beyond reputeclutch man has a reputation beyond reputeclutch man has a reputation beyond reputeclutch man has a reputation beyond repute
Default
Thanks guys!!
It should be the clutch puller for the 02 and newer Polaris big twins.
the clutch determines the puller yes.
  #4
Old 06-07-2010, 10:14 PM
Default
THANK YOU GUYS!!
__________________
see ya at the top!
  #5
Old 06-08-2010, 04:39 AM
longhairfreak longhairfreak is offline
Currently: Wondering how crfFred is doing?
Basic Member
longhairfreak has a reputation beyond reputelonghairfreak has a reputation beyond reputelonghairfreak has a reputation beyond reputelonghairfreak has a reputation beyond reputelonghairfreak has a reputation beyond reputelonghairfreak has a reputation beyond reputelonghairfreak has a reputation beyond reputelonghairfreak has a reputation beyond reputelonghairfreak has a reputation beyond reputelonghairfreak has a reputation beyond reputelonghairfreak has a reputation beyond repute
Default
The clutch and crank determine the puller. I have a polaris clutch on a cat bottom end and need a custom puller.
  #6
Old 06-08-2010, 09:59 AM
Scott's Avatar
Scott Scott is offline
Currently: ACTIVELY defend your right to ride.
Polaris & Montana Moderator
Scott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond repute
Garage
Default
Dick, you need the standard p85 puller for the 800rmk, but you need to machine a little more taper into it our you'll booger up the threads inside the PTO end of the crank. You don't want that.
You do have to modify the puller. I'll post pics of mine.
__________________
OEM parts from Free Agent
Ambassador for:
FB & IG: Scott Stiegler
Honestly, Honey!!! The shop paid for these mods. They sponsor me now. Really!
Check out these cool products:
  #7
Old 06-08-2010, 11:13 AM
Default
OK so here's what i have done. The puller I have is the standard polaris p85 puller and it threads perfectly into the standard p85 I am trying to remove from the PSI 1085 motor with RAD crank. Since i was having the problem of getting the 1085 clutch off I checked the puller on my PSI 890 crank which is also a RAD crank and the tip of the puller seemed to fit into the 890 crank hole just fine leaving more than enough room that should be necesary to pop the clutch without bumping up against the crank.
Knowing that the puller seemed to fit just fine with the 890 crank I thought I should be good to go using it on the 1085.........it sounds like your experience has been different??
__________________
see ya at the top!
  #8
Old 06-08-2010, 12:12 PM
Scott's Avatar
Garage
Default
Your 890 is a top-end kit right? The bottom end is a Polaris OEM case and RAD crank.
__________________
Ambassador for:
  #9
Old 06-08-2010, 03:57 PM
1200psi 1200psi is offline
Currently: is tripin and cripin
1200psi has a reputation beyond repute1200psi has a reputation beyond repute1200psi has a reputation beyond repute1200psi has a reputation beyond repute1200psi has a reputation beyond repute1200psi has a reputation beyond repute1200psi has a reputation beyond repute1200psi has a reputation beyond repute1200psi has a reputation beyond repute1200psi has a reputation beyond repute1200psi has a reputation beyond repute
Default
YOU have to machine the end of the puller down because psi used a 12mm bolt instead of the 14 mm witch is stock. IF you havent already ruined the threads putting the stock puller and trying to get it off you will so you need to machine the end of the puller down so it is smaller than the id of 12 mm bolt.
Brad
  #10
  #11
Old 06-08-2010, 04:00 PM
Click Here to Register
  #12
Old 06-08-2010, 04:31 PM
Scott's Avatar
Garage
  #13
Old 06-08-2010, 05:03 PM
  #14
Old 06-08-2010, 09:46 PM
Scott's Avatar
Garage
  #15
Old 06-08-2010, 10:11 PM
  #16
Old 06-09-2010, 09:42 AM
Basic Member
  #17
Old 06-09-2010, 05:26 PM
mattymac's Avatar
mattymac mattymac is online now
Currently: investing in lead
mattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond repute
  #18
Old 06-10-2010, 09:50 AM
Scott's Avatar
Garage
  #19
Old 06-10-2010, 11:12 AM
  #20
Old 06-10-2010, 02:02 PM
Scott's Avatar
Garage
  #21
Old 06-10-2010, 02:22 PM
Basic Member
  #22
Old 06-19-2010, 04:27 PM
  #23
Old 06-21-2010, 12:54 PM
Scott's Avatar
Garage
  #24
Old 07-01-2010, 09:03 PM
w browning w browning is offline
Currently: doing the snow dance
w browning has a reputation beyond reputew browning has a reputation beyond reputew browning has a reputation beyond reputew browning has a reputation beyond reputew browning has a reputation beyond reputew browning has a reputation beyond reputew browning has a reputation beyond reputew browning has a reputation beyond reputew browning has a reputation beyond reputew browning has a reputation beyond reputew browning has a reputation beyond repute
  #25
Old 07-01-2010, 10:44 PM
Scott's Avatar
Garage
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
no new posts
