Upgrade to Premium
Reply
  #1
Old 12-12-2017, 07:56 PM
Goinboardin's Avatar
Goinboardin Goinboardin is offline
Currently: ..current
Goinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond repute
Default Another Baofeng Thread: BF-F8HP vs UV-82HP?
Both are spec'd to cover the same frequencies and now have the same output ratings (8W VHF/7W UHF). https://baofengtech.com/comparechart
The BF-F8HP has a bigger 2100mAh battery versus the UV-82HP with 1800mAh battery. I'd be using a BTech mic, and can add an antenna if needed. My buddies use BCA and they work OK if nearby (they love them, I find the range inadequate), but I'm also on SAR and would like a radio with more range and flexibility.
Any real differences for a sledding radio? Input is appreciated. Thanks.
__________________
2013 XM 800 153
Rate this post: Yes | No
  #2
Old 12-19-2017, 11:53 AM
blastco2 blastco2 is online now
Currently: Not set.
blastco2 has a reputation beyond reputeblastco2 has a reputation beyond reputeblastco2 has a reputation beyond reputeblastco2 has a reputation beyond reputeblastco2 has a reputation beyond reputeblastco2 has a reputation beyond reputeblastco2 has a reputation beyond reputeblastco2 has a reputation beyond reputeblastco2 has a reputation beyond reputeblastco2 has a reputation beyond reputeblastco2 has a reputation beyond repute
Default
I would use the f8hp with the 7 inch baofeng antenna and a counterpoise.
I have tried many different antennas, the 7 inch baofeng always works the best.
The f8hp has the bigger batt and more accessories available.
Sent from my VS990 using Tapatalk
The Following User Says Thank You to blastco2 For This Useful Post:
Goinboardin (12-22-2017)
  #3
Old 12-19-2017, 11:55 AM
Currently: Not set.
Default
The btech mic is a really good choice.
But 2 of the radios and give one to a BCA user to try....
He will likely switch....
  #4
Old 12-27-2017, 01:49 PM
Default
I ordered an F8HP with Btech mic and programming cable, hopefully get some use of it this weekend.
__________________
2013 XM 800 153
  #5
Old 12-27-2017, 02:33 PM
christopher's Avatar
christopher christopher is offline
Currently: Husky Powered, Woof Woof
christopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond repute
Garage
Default
Speaking as an Extra-Class HAM, NOTHING beats POWER and ANTENNA..
Consider this one instead.
http://qrznow.com/baofeng-uv9r-plus-...nd-fm-vhf-uhf/
https://www.aliexpress.com/item/2PCS...839869039.html
Baofeng UV9R Plus
Product parameters
Frequency Range: VHF 136-174,UHF 400-520MHz
Theoretical communication distance: 10 km
Power: 15WATTS
Battery: Polymer lithium battery
Battery: 8000 mAh
Weight: 0.5kg
__________________
The Following User Says Thank You to christopher For This Useful Post:
skegpro (12-27-2017)
  #6
Old 12-27-2017, 05:07 PM
skegpro skegpro is offline
Currently: Not set.
Basic Member
skegpro has a reputation beyond reputeskegpro has a reputation beyond reputeskegpro has a reputation beyond reputeskegpro has a reputation beyond reputeskegpro has a reputation beyond reputeskegpro has a reputation beyond reputeskegpro has a reputation beyond reputeskegpro has a reputation beyond reputeskegpro has a reputation beyond reputeskegpro has a reputation beyond reputeskegpro has a reputation beyond repute
Default
Baofeng UV9R Plus
Product parameters
Power: 15WATTS
Battery: 8000 mAh
Weight: 0.5kg
Looks awesome.
Did you buy one off this link you attached?
Its only showing 8W........
Sent from my FRD-L14 using Tapatalk
  #7
Old 12-27-2017, 05:42 PM
Garage
Default
Quote:
Originally Posted by skegpro View Post
Looks awesome.
There are a PILE of links to ALI...
https://pt.aliexpress.com/item/Baofe...OrigTitle=true
But this is brand new.
Not even listed on the manufacturer's page yet.
Saw it on QRZ but i am not sure it is actually shipping or not yet.
__________________
  #8
Old 12-27-2017, 07:04 PM
Currently: Not set.
Basic Member
Default
Yes great find, I am not seeing the 15W info anywhere except the link you provided.
Must be new.
The link to Alibaba they are showing pictures of the UV-9R nonplus version.
Makes me a little nervous to order.
  #9
Old 12-27-2017, 07:29 PM
Garage
Default
Must be new.
Agreed.
Even the link posted on QRZ to order it takes you back to the 8W version.
__________________
  #10
Old 12-27-2017, 11:56 PM
rotaryboots rotaryboots is offline
Currently: Not set.
Basic Member
rotaryboots is an unknown quantity at this point
Default
I've got a BCA BC-Link and use it as my primary radio, but also keep a
Baofeng UV-82 and an external mic with a long Nagoya Whip antenna in my pack as a backup, spare for extra riders, communicate with Emergency Services, etc.
  #11
Old 12-28-2017, 09:47 AM
Currently: Not set.
Basic Member
Click Here to Register
  #12
Old 12-28-2017, 09:11 PM
The Following User Says Thank You to Goinboardin For This Useful Post:
christopher (12-29-2017)
  #13
Old 12-29-2017, 12:02 AM
Currently: Not set.
  #14
Old 12-29-2017, 11:31 AM
Currently: Not set.
Basic Member
  #15
Old 12-29-2017, 02:25 PM
Currently: Not set.
  #16
Old 12-29-2017, 06:52 PM
Currently: Not set.
Basic Member
  #17
Old 12-29-2017, 07:30 PM
Garage
  #18
Old 12-29-2017, 08:20 PM
Currently: Not set.
Basic Member
  #19
Old 02-05-2018, 12:06 PM
blastco2 (03-04-2018)
  #20
Old 08-02-2018, 09:10 AM
donbrown (08-09-2018)
  #21
Old 08-02-2018, 09:20 AM
Garage
  #22
Old 08-02-2018, 10:35 AM
  #23
Old 08-04-2018, 12:47 PM
Timbre's Avatar
Timbre Timbre is offline
Currently: Let 'er SNOW!!
Timbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond repute
  #24
Old 08-17-2018, 12:09 AM
Currently: Not set.
christopher (08-19-2018)
  #25
Old 08-17-2018, 08:12 AM
Timbre's Avatar
Reply
Bookmarks
Tags
baofeng, bf-f8hp, radio, uv-82hp
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Baofeng and BCA Radio's Thread Starter — ryanjeri Forum — Communications - Radios Replies — 18 Last Post — 02-05-2018 12:55 PM
Thread — baofeng 888S Thread Starter — mx100 Forum — Communications - Radios Replies — 19 Last Post — 12-17-2016 10:07 AM
Thread — Heli-Coil thread repair kit - M10x1.25 metric thread Thread Starter — Bocephus Forum — Tools/Shop Items (Swapmeet) Replies — 0 Last Post — 12-02-2012 09:10 AM
Thread — For those that hate the old max thread and the new rep thread. Thread Starter — Bubba700 Forum — Fouled Plug Replies — 50 Last Post — 10-05-2010 05:17 PM
