Looks like 2020 engine will inject oil direct to bottom end not through reeds like 18/19 engine's.And my guess is injection angle change has something to do with bottom end lubrication also.
Just at 1000 miles on my '18 Mountain Cat. Stock except for SSI Ti can. I ride Colorado & Wyoming in deep fluffy snow and no snow ingestion issues at all. Multiple days of over the hood, pinned all day.
Many of the issues I've seen are from snow ingestion and a few oil issues. I do think the 2020 version is an improvement.
Sled just rips! Granted, it is a two stroke but, I hope the good luck continues.
Oil used?2019 Alpha, 1050 km seized solid today.
Oil used?
Oil ratio?
Completely stock?
reduce
On that note, any thoughts to a lean condition by dropping the fuel mixture in a computer controlled environment?
All of the new ones are running way to lean, too little fuel and too little oil. It is the only way they can meet emission standards.
Worse yet they are all going away from running a fuel/oil mix in the case and transfer ports. To me that means less consistent lubrication at an already lean ratio and no way to really fix it. Adding oil to the fuel wont work to lube the bottom end anymore. Polaris has been like this for a while and their reliability still sucks. I am not familiar with the Doo set up since I can't ride those...
